Activity › Forums › Compression Techniques › Microsoft mpeg4 v 2 on a Mac?
Posted by Luke Hale on November 29, 2007 at 2:36 amHi,
Is there a way I can encode video in Microsoft mpeg4 v2 on a Mac? If not, what is the best way to encode in that exact format?
Thanks a lot,
Luke
Daniel Low replied 18 years, 9 months ago 3 Members · 6 Replies -
Craig Seeman
November 29, 2007 at 4:27 pmWhile Flip4Mac can certainly play back that codec on the Mac, I can’t even FATHOM why you’d want to encode to MPEG4v2. Is this for playback on antique computers?
Heck I don’t even think Windows Media Encoder on Windows encodes anything older than WMV7
Even Windows Media Player 7.1 can play back Windows Media Video 9 files. WMP7.1 works on nearly 10 year old Windows 98. If someone hasn’t moved beyond WM98 SE then I’d either get them an OS upgrade or a new computer.
Luke Hale
December 2, 2007 at 8:42 pmIt’s for playback on a photobooth, basically a demonstration video that will play when it is not in use. Apparently MPEG4 v2 is the only format that will play on the device. Is there maybe a modern, similar equivalent that might work? I have tried Flip4Mac and it’s no good. Any other suggestions greatly appreciated!
Luke
Luke Hale
December 2, 2007 at 9:27 pmJust in case anyone ever has the same problem, I used a piece of software called Video Converter for Mac, https://www.mp4converter.net/video-converter-mac.html, to encode to Mpeg4 v2. Problem solved!
Craig Seeman
December 2, 2007 at 9:50 pmNowhere does it show support for Mpeg4v2
See this article
https://en.wikipedia.org/wiki/Windows_Media_Videoand see this when you scroll down
Microsoft MPEG-4 Video Codec V2 MP42 Video for Windows-based codec. Non-standard MPEG-4 codec incompatible with the later standardized version of MPEG-4.
Luke Hale
December 2, 2007 at 11:25 pmUmm, I realise it may not show support for the codec, but I did just use the program and encoded MS mpeg4 v2 successfully. It may seem suprising but it definately does work.
Daniel Low
December 6, 2007 at 11:55 am
