Activity Forums Adobe Premiere Pro Microsoft Built In Compressor sufficient?
  • Microsoft Built In Compressor sufficient?
    Posted by Eric Freeman on July 8, 2008 at 10:18 pm
    I have Adobe Premiere Pro 2. I don’t have any digital capture hardware or anything like that.
    I am running my video through some color correction filters. When I render the footage, I assume it’s using Microsoft’s DV AVI codec. I’ve heard this codec isn’t the best.
    Even though my final output is an MPEG-2 file (for export into Encore), I think it’s still using the codec to render the color correction filters.
    1. Is that right?
    2. If so, is the codec it’s using good enough not to cause any significant quality loss?
    3. Is there anyway to change what codec Premiere uses for this?
    Harm Millaard replied 18 years, 2 months ago 2 Members · 1 Reply
  • Harm Millaard
    July 8, 2008 at 10:51 pm
    Yes, yes, no. If you use other footage with a different codec you have to adapt your project settings accordingly or convert to DV AVI type2.
    Harm Millaard
