Activity Forums Adobe Premiere Pro Microsoft AVI DV codec locks up Pro 2.0
  • Microsoft AVI DV codec locks up Pro 2.0
    Posted by James Moor on May 30, 2007 at 12:32 pm
    For reasons i can’t figure out, if i export from Pro 2.0 using the “Microsoft AVI DV” setting, the resulting .AVI file locks up my machine. The .AVI file seems to render normally (a little slow) but when i open the folder into which the .avi resides, Windows-XP(sp2) locks up, Dr. Watson does it’s thing and i ultimately have to reboot my machine to regain control. If i use the “Microsoft AVI” setting (rather than the MS AVI DV setting) everything works fine.
    Could this be a corrupted MS AVI DV codec? I’ve searched MS downloads site but i don’t see where I can just download that specific codec.
    Anyone have any thoughts?
    TIA,
    jd
    Jevans replied 19 years, 3 months ago 2 Members · 1 Reply
  • Jevans
    May 31, 2007 at 2:16 am
    I had a problem way back with various .avi files locking up my sytem and the same thing happened. Dr.Watson(useless!) would freeze my whole computer and I’d have to manually shutdown. I browsed Google for about 3 hours and found a thread about a solution. I hope it works for you too but it may have nothing in common with your problem.
    Problem: Quicktime Player Settings
    Under the ‘Recently Played’ files/movies list, clear the list. I’m not sure which menu it’s under, but as soon as I cleared this list everything was fine, and no more problems with .avi files. I have no idea why this caused my problem, but it fixed it. I can’t recall if there is a way to show no recently opened files or not, but just constantly clear it if you have to. Also I think since I have installed a newer version of Quicktime it is not a problem.
    Hope this helps, or leads you the right way.
