Activity › Forums › Adobe After Effects › Microphone visible in top right-hand corner of frame
Posted by Diy on May 20, 2006 at 5:54 pmHi
Like a fool I allowed my cam mike to dip into shot whils doing a wedding.
Is there a work around in AE 7.0 which will allow me to loose the mike?
Fortunately the background surrounding said mike is wall – so I hope i can loose the mike for synthetic wall..Regs
Diy replied 20 years, 3 months ago 4 Members · 6 Replies -
Roland R. kahlenberg
May 20, 2006 at 8:19 pmIf it’s a flat-colored wall with no shadowing or other visible light-related sprays then the Clone Brush would work nicely. A faster workaround would be to scale up the footage and reposition it such that the mike gets pushed into the pasteboard area.
HTH
RoRK
broadcastGEMs
customizable animated backdrops with Adobe After Effects project files -
Andy Taplin
May 26, 2006 at 9:31 amCreate a duplicate layer of your shot, then make a small mask on the original layer where the mike is to make a ‘hole’ looking through to the duplicate layer below.
Move the dupe layer until a patch of wall without the mike is filling the hole.
Andy
Diy
May 27, 2006 at 6:12 pmAndy..
Many thanks for this..
I am getting somewhere here. However when I move the duplicate layer around all I see of the orignal layer is the mask of the mike.. nothing else remains!
So the one bit i wanted to be a “hole” has remained full of microphone if that makes sense..Regs
Rupert
Andy Taplin
May 28, 2006 at 4:35 pmTry inverting the mask and/or swapping the layers over. Eventually you should see what you want.
Diy
May 28, 2006 at 5:31 pmWill do…. I am sure I will get there in the end..!
Once again tks for your help..
Rupert
