Activity Forums Audio Microphone stand thread: 5/8 vs 15mm
  • Microphone stand thread: 5/8 vs 15mm
    Posted by Andrew Taylor on October 12, 2015 at 6:47 pm
    I always thought the convention for a microphone stand thread was 5/8 – 27 (extra fine thread; the standard industrial sizes being 5/8 – 11 for coarse thread and 5/8 – 18 for fine thread).
    However, I recently came across a type of microphone stand that uses a 15mm thread (and when I say I came across it, I mean I bought it and discovered the thread was not a match).
    Is 15mm a newer standard, or is it only used in other parts of the world? If there are two coexisting standards now (5/8-27 and 15mm), are there any adaptors to convert from one to the other?
    Andrew Taylor replied 10 years, 10 months ago 3 Members · 3 Replies
  • Ty Ford
    October 12, 2015 at 8:25 pm
    Hello Andrew,
    If the below works with what you’re talking about, you do see the 15mm in Europe.
    Many mics sold today come with one of these already in the 5/8″ mic mount.
    https://www.fullcompass.com/prod/256966-Manfrotto-MIBA?utm_source=googleps&utm_medium=shopping&utm_campaign=googleps&gclid=CMazqdHhvcgCFUMTHwod8VgJ7A
    Regards,
    Ty Ford
    Cow Audio Forum Leader
    Want better production audio?: Ty Ford’s Audio Bootcamp Field Guide
    Ty Ford Blog: Ty Ford’s Blog
  • Richard Crowley
    October 12, 2015 at 10:06 pm
    I believe Mr. Taylor and Mr. Ford are talking about different things. 15mm is quite a bit larger than the 3/8 adapter cited.
    I have seen cheap mic booms (from Guitar Center) that appeared to have some sort of “adapter” on the end which at first inspection appear to be 5/8-27 to 5/8-27. But on closer inspection, the threading on the pipe (and the female threads on the “adapter” might be that odd-ball 15mm that Mr. Taylor is asking about. Perhaps it is cheaper to thread the pipes to 15mm and use an adapter to 5/8-27 than to use a proper 5/8-27 die. (or perhaps the pipe is 15mm vs 5/8 inch?)
  • Andrew Taylor
    October 14, 2015 at 4:04 pm
    Thank you for the link, but I think Richard is right. The 15mm mentioned in the adapter description refers to how long the adapter is, not the thread (which is 5/8-27 to 3/8-16).
    I thought of retapping the female 15mm thread at the base the of microphone clip, since all the male counterparts (microphone stand, boom pole, etc.) are the standard 5/8-27 already.
    But the microphone clip came with its own set of adapters: one for a regular hot shoe, one for a mini hot shoe, one for a gorilla pod-type set of legs. So if I retap the female end of the microphone clip, I cannot use any of the accessories that came with it.
    I was hoping someone would manufacture a 5/8-27 to 15mm converter that I could use.
    Alternatively, I could get this thread saver (https://www.bhphotovideo.com/c/product/1076269-REG/latch_lake_thsvr_5_8_thread_saver.html) and retap the male end of it to 15mm. But by the time I purchase the thread saver, plus a die, plus a die wrench, I’m better off buying a different microphone clip.
