Activity Forums DaVinci Resolve Micro Panel Connectivity issues
  • Micro Panel Connectivity issues
    Posted by Johan Windh on December 7, 2022 at 8:04 am
    For some time I’ve had issues with my Micro Panel. Sometimes when starting up Resolve it will not connect. It has power (is lit up) but it takes several minutes for it to connect.
    I have the latest firmware (I guess, it doesn’t seem to be any proper other than the Panels Setup app.)
    I’ve tried to reset the panel to factory settings. Doesn’t work.
    Using Resolve Studio 17.4.6 on a Mac Studio M1 Max, Ventura 13.0
    John Calhoun replied 3 years, 7 months ago 3 Members · 3 Replies
  • Michael Gissing
    December 8, 2022 at 2:30 am
    There was something about panel connectivity with the version 18 releases. Perhaps read the release notes and if it works for you to update the software then version 18 has lots of improvements over version 17 as well as panel updates. Database will need a backup as version 18 does do a database update
  • Johan Windh
    December 14, 2022 at 8:06 am
    Thanks Michael. I’m currently in the middle of a big project and am unable to switch to 18 at the moment.
  • John Calhoun
    February 10, 2023 at 8:28 pm
    Same here. I’m on 18.1.3 and 2.0 on the Micro and it isn’t working. I just started working here and thought it was a connection issue, but apparently it’s something else.
