Activity Forums Audio Mic white noise
  • Mic white noise
    Posted by Aaron Bevill on June 30, 2008 at 5:11 pm
    I work for a college where we have started recording podcast style lectures to offer our students. I’m pretty new to audio and have been trying to figure out how to eliminate some noises during recording. The only way I can describe it is kind of a white noise. It might just be the room we are recording in or maybe the mic is too hot. you can listen to a sample of it here. The file is titled test.wav. We are using a Shure SM7B connected to a Macbook Pro with a M-Audio firewire 410 and a PreSonus Eureka Pre-amp. I’ve used the suggested settings for vocal on the pre-amp but can’t seem to get rid of the noise.
    Randy Wheeler replied 18 years, 1 month ago 4 Members · 11 Replies
  • 11 Replies
  • Peter Perry
    June 30, 2008 at 6:56 pm
    Hey Aaron,
    This sounds like poor gain structure.
    How do you have this stuff connected…..in what order?
    Peter
  • Aaron Bevill
    June 30, 2008 at 8:09 pm
    I have the mic going into the Eureka Pre and then into the 410 into the Macbook Pro.
  • Peter Perry
    June 30, 2008 at 8:41 pm
    Forget that last question….it was stupid. I have been up since 3 am and my brain isn’t working too well. I hate early morning crew calls. 🙂
    It still sounds like poor gain structure to me. Do you have the gain on the 410 cranked….or really low, so you have to crank up something else? The goal is to have all your gain stages working optimally.
    Peter
  • Aaron Bevill
    June 30, 2008 at 8:44 pm
    I’ve tried it at different stages. Mainly it stays around 75% up on the 410 I would guess.
  • Ty Ford
    June 30, 2008 at 11:22 pm
    Hello Aaron,
    Try just plugging the mic in to the 410, lose the presonus. See what happens.
    Regards,
    Ty Ford
    Want better production audio?: Ty Ford’s Audio Bootcamp Field Guide
    Watch Ty play guitar
  • Aaron Bevill
    July 1, 2008 at 6:24 pm
    Thanx for all the posts so far. I have tried going straight into the 410 but we can’t get the volume levels we need using the SM7B. I do hear the noise when i crank the 410 alone as well. Not as much but it is there.
  • Ty Ford
    July 1, 2008 at 6:32 pm
    The SM7b is supposed to be worked closely, like 2-3 inches.
    Where are you on it?
    Regards,
    Ty Ford
  • Aaron Bevill
    July 1, 2008 at 6:42 pm
    Yeah we have people right on it when we are recording. We couldn’t get much volume so we bought the Pre-amp on a suggestion from the audio guys at guitar center.
  • Ty Ford
    July 1, 2008 at 7:18 pm
    That ain’t right. (not doubting you, just sounds weird that it’s that low)
    The M-audio 410 should have more poop than that.
    What sort of cable are you using?
    Regards,
    Ty Ford
  • Aaron Bevill
    July 1, 2008 at 7:53 pm
    XLR cable not really sure what brand or anything. We only get around -24db max in Logic when going straight through the 410 at full gain.
