Activity Forums Audio Mic click
  • Mic click
    Posted by Craig Williams on August 29, 2019 at 8:34 pm
    My voice over studio set up is simple. Scarlet Solo, Rode NT1 Mic going to an iMAC using Reaper. Once in a while I get a very short electrical click on my waveform and it seems to happen when my AC or other load kicks on. I have plugged everything into a surge protector and it still does help. The strange thing is, when I use my MKH416, it doesn’t happen.
    Any ideas?
    Craig’s Voice Over Website: British Voice Over.
    Craig’s Blog: British Voice Over Blog.
    Richard Crowley replied 7 years ago 3 Members · 2 Replies
  • Ty Ford
    August 29, 2019 at 9:37 pm
    Hello Craig and welcome to the Cow Audio Forum.
    It sounds like a sample rate issue, although from what you say, it’s hard to figure.
    If the sample rate for the session is set to 44.1 kHz on the software but the hardware is set to 48 kHz, or vice versa, you will get occasional ticks as the sample rates fight.
    Make any sense?
    Regards,
    Ty Ford
    Cow Audio Forum Leader
    Want better production audio?: Ty Ford\’s Audio Bootcamp Field Guide
    Ty Ford Blog: Ty Ford\’s Blog
  • Richard Crowley
    August 30, 2019 at 3:09 am
    If you have correlated the noise with mains power line events, that strongly suggests power-line interference is the root problem. So your attention to the power line is a good instinct IMHO.
    Bur a “surge protector” is not anything like a power line noise filter. I would go so far as to say that a “surge protector” that cost less than $100-200 may not be much of a “surge protector” either. Most “surge protectors” are $3 plastic power strips with a single-use MOV (metal oxide varistor) that cost 72 cents. And they they charge you 20x for the warm feeling of protection.
    If I had that problem, I would first attempt to discover exactly which loads in your house are causing the transients. Then you can apply a snubber across the switch contacts. Always better to stop the transient at the source than try to protect yourself downstream.
    It has always been the case that some microphones are more sensitive to power noise than others. No real surprise there.
    Something like these are what I would consider minimum “noise filters”
    https://www.amazon.com/dp/B00IX04FDW/
    https://www.amazon.com/dp/B003PJ6NPO/
    Recording audio without metering and monitoring is exactly like framing and focusing without looking at the viewfinder.
