Activity Forums Adobe After Effects Mettle Skybox V2 Compose odd behaviour…..
  • Mettle Skybox V2 Compose odd behaviour…..
    Posted by Casey Dobie on May 25, 2017 at 11:04 pm
    Hey everyone. Not sure if this is the right place but did notice a few other people asking for advice on the fantastic skybox software.
    Been using composer for a few days and suddenly something very strange is happening. Any thought would be hugely appreciatoed.
    I’m working in a 3d skybox composer comp. Everything works fine – I can add graphics – look around – as I would expect. I have a 2d comp as well where I have just masked the rig.
    When in the Edit 1 2d comp and I click Open Output – nothing happens. If I manually go to the Output comp the mask is there and the rig is gone. Everything as it should be.
    However – when in edit 2 (the 3d comp) I can see everything fine and I can look around, add graphics in 3d etc. But when I click Open Output nothing happens, and when I manually go to the Output comp – none of the 3D graphics are there.
    Opening the Skybox Conversion comp reveals the 2 edit layers. Double clicking the Edit 1 comp takes me to the correct Edit 1 comp with the rig mask.
    Double clicking the Edit 2 comp takes me to another comp called Skybox Conversion – which is empty.
    Double clicking that takes me to another comp called Project Name (SkyBoxV2 Edit2) (3D) (combined) – which is empty.
    Output comp resolution 4320 x 2160
    Edit 1 (2D) resolution 4320 x 2160
    Edit 2 (3D) resolution 1920 x 1080
    (SkyBoxV2 Edit2) (3D) (combined) resolution – 4320 x 3240
    This is worrying as there is a whole day of adding graphics that I can’t render out.
    Any thoughts. I’m on a tight deadline ☹️????????
    Casey
    Casey Dobie replied 9 years, 3 months ago 1 Member · 0 Replies
  • 0 Replies
