Meter clipping in STP and FCP but sounds fine as quicktime
I recorded an announcement at 48k into STP 3.0.1 and levels were
were between -14dB and -6dB.
I exported to Final Cut and the made both .aif and .wav files. When I play them thru a PC running Station Playlist, the announcements are a lot softer/quieter than the music that plays before and after.If I bring one of the CD music files into FCP, the meter is clipping like crazy so I have to bring the levels down to about -10dB.
When I went back to up the audio levels of the announcement by bringing it back into STP, normalized to 0 dB, compressed it, brought it back into FCP, played it and could see it was between -6db
&clipping, then output it anyway as a .wav and played it using Quicktime player, it sounded fine.
So I loaded into the PC playing StationPlaylist, and it was fine, comparable to the music levels.
Why does it sound bad/clipping in FCP and STP, but when I output it as an .aif or .wav, it sounds fine?
Want better production audio?:
