Activity Forums Apple Final Cut Pro Legacy metallic sound.
  • metallic sound.
    Posted by Many on November 13, 2005 at 3:36 am
    Hello to everyone.
    I have another new challenge on my procces in learning as much as I can about video and video editing. Sound…….. This job I did, didn’t have a sound person around to ask question but I still adventure to run a XLR cable from a (BOX?) that had 5 mic’s imput and one speaker output. The box was small but i don’t know exactly what it was. Anyway. I connected my xlr cable to the output that was free and into my camera xlr imput (Panasonic dvx100a). The sound was very loud and I had to move the manual control to very low imput but the audio ended up sounding like…metallic…talking inside of a can kind of. I thought that I will be able to fix it in FCP anyhow but I realized that it my be difficult. I”m reading as much as I can about the subject but I was also hoping the someone with more experience could give a little push or direccion to go.
    Thanks a lot for alking the time.
    Os
  • Bouncing Account needs new email address
    November 13, 2005 at 4:59 am
    [many] “I thought that I will be able to fix it in FCP anyhow but I realized that it my be difficult.”
    I doubt that you’ll ever get it into better shape, if its what I assume and was improperly connected to the wrong output on the “box” (mixer) in relation to the input on the camera.
    I’m guessing that the output was LINE-level and the input in the camera was set to MIC-level.
    This will resort in irreparable distortion.
    There are many books about matching output to inputs, and you should spend some time with them as well as working with a good audio person to learn the techniques.
    In the mean time, I suggest that if you don’t KNOW for SURE what kind of connections and settings to use, you’d be much better-off just using the on-camera mic.
    If the track you recorded is in the condition you described (and I am assuming) it is quite likely beyond anyone’s help.
