Activity › Forums › Adobe After Effects › Metal Press effect?
Metal Press effect?
Posted by John Bauwens on May 12, 2011 at 4:19 amSo I am building a bumper in AE, and I was wondering how to do an effect like a metal press. Sort of a stamping effect. Any input on this?
Tudor “ted” jelescu replied 15 years, 4 months ago 2 Members · 3 Replies -
Tudor “ted” jelescu
May 12, 2011 at 5:59 amYou can use Free Form (stock with CS5) to create a 3D displacement. Add a Light and you can animate the depth of the extrusion.
Here’s a tutorial that can help you figuring out Free Form:
https://library.creativecow.net/jelescu_tudor/3D-from-2D-image_AE/1Tudor “Ted” Jelescu
Senior VFX Artist -
John Bauwens
May 12, 2011 at 6:08 amMy apologies,
I should have stated that I am still using CS3, and we really don’t have the resources to dump into upgrades right now. Is this still possible?
Tudor “ted” jelescu
May 12, 2011 at 7:45 amYou can still try and use displacement with the stock plugin under Distort. It will be a 2d effect though.
You may even get away with creating 3 or 4 stills in PSD (use bevel/emboss and drop shadow to “grow” the shape pressed in) and then adding a motion blur and camera shake in AE, simulating a hard hit from the press.Tudor “Ted” Jelescu
Senior VFX Artist
