Activity Forums Avid Media Composer metafuze
  • Posted by Geraint Pari huws on May 27, 2014 at 2:34 pm
    Where am I going wrong, I’m importing file sequences via metafuze, process is fine when I import 1080 185 10bit, but, when I select uncompressed 10bit, the new transcoded mxf files roll horizontally. Any suggestions gratefully accepted.
    Geraint Pari huws replied 12 years, 3 months ago 2 Members · 2 Replies
  • Michael Phillips
    May 27, 2014 at 3:16 pm
    I need to go back and look at MetaFuze. It has been a loooong time since I’ve used it. Basically since Resolve was free and it makes native MXF media. 🙂
    But in your case, you’re trying to make uncompressed MXF which is not part of the Resolve export functions, so I can see your need to use MetaFuze. The last time I installed it, it wouldn’t launch, so when I get time, I will try again.
    Michael
  • Geraint Pari huws
    May 27, 2014 at 3:33 pm
    I use resolve, but as a one(ish)stop shop, metafuze is fairly simple, and scans dpx folders really efficiently
