Activity Forums Apple Final Cut Pro Legacy Messing with Audio in FCP
  • Messing with Audio in FCP
    Posted by Jared Smith on February 8, 2009 at 8:50 pm
    hey guys,
    i did alot of interviews for a documentary. there is a very high pitch ring in the interviews when i turn the tracks up to a decent audible volume. is there a way to get rid of that high ring tone without taking it into soundtrack pro?
    thanks guys
    jared
    Ernie Santella replied 17 years, 7 months ago 3 Members · 2 Replies
  • Ben Holmes
    February 8, 2009 at 9:09 pm
    If the ring is a higher frequency than the speech you should try a low pass filter to remove it. I think that’s right (and it’s not the high pass filter) – I always get these the wrong way around, and I’m pretty sure it’s the one you think it isn’t…. If you see what I mean.
    Anyway – should be pretty fixable. If the audio level is low, there’s a gain audio filter as well.
    Ben
    Edit Out Ltd
    FCP Editor/Trainer/System Consultant
    EVS/VT Supervisor for live broadcast
    RED camera transfer/post
    Independent Director/Producer
  • Ernie Santella
    February 9, 2009 at 4:22 am
    A notch filter might be a better bet as the low-pass might be a bit too much as it will cut all frequencies above the cut-off. A notch filter can be more selective and just cut the noise tighter.
    Ernie Santella
    Santella Productions Inc.
    http://www.santellaproductions.com
