Activity Forums Apple Final Cut Pro Legacy Message saying unknown codec?
  • Message saying unknown codec?
    Posted by Jonny Cates on October 5, 2012 at 11:36 pm
    I’ve converted some of my own finished DV footage back to Prores, taken from a perviously completed DVD. I have it cut up in several pieces and placed it into a new sequence for editing. I started to do a render, but now I get this message:
    “Codec not found. You may be using a compression type without the corresponding hardware card.”
    What does this mean? I converted all the footage back to ProRes from the DVD, as previously instructed.
    The compressor setting on the timeline is set on Apple Pro Res – and unlimited RT and (or) nothing else is available to choose from – except for play base layer only, full quality, and use playback settings.
    Don’t know what to do….
    Jonny Cates
    Jonny Cates replied 13 years, 7 months ago 2 Members · 2 Replies
  • Steve Eisen
    October 6, 2012 at 8:37 pm
    [Jonny Cates] “I have it cut up in several pieces and placed it into a new sequence for editing. I started to do a render, but now I get this message:
    “Codec not found. You may be using a compression type without the corresponding hardware card.””
    If you haven’t added any affects or transitions, you shouldn’t have to render anything.
    Steve Eisen
    Eisen Video Productions
    Vice President
    Chicago Creative Pro Users Group
  • Jonny Cates
    October 6, 2012 at 9:17 pm
    Yea Steve, I just figured that out. I decided I wanted a few a few transitions when this all started. However, I discovered that if you set the sequence setting to “NONE”…it will render. Thanks.
    Jonny Cates
