Activity › Forums › Maxon Cinema 4D › Mesh Tools for C4D
Mesh Tools for C4D
Posted by Sergei Opanasuk on February 19, 2009 at 2:59 pmHello Everyone!!!!
I used to use MeshTools script for 3D Studio Max.
Do you know if any script like that exist for C4D.
Thank you very much for your feedback!!!!sergei
Carver Koella replied 15 years, 7 months ago 3 Members · 7 Replies -
Adam Trachtenberg
February 19, 2009 at 3:24 pmMost of the MeshTools functions are built into Cinema. There’s a free plugin (ama multislide) that duplicates the loop slide function which you can dowloand from here: https://www.remotion4d.net/downloads_d2.php
Sergei Opanasuk
February 19, 2009 at 3:42 pmThanks. That looks like a really good plug-in. Cannot wait to get home from work to try it out.
Do you know any plug-ins that may help to loop cut edge/poligon in half.
Thank you!!!sergei
Sergei Opanasuk
February 19, 2009 at 5:26 pmYep. I think i know how to use Knife tool. Do you think if i can loop cut edge/polly in 2,3 or 4 even pieces without setting the offset value? Sorry, i guess i just like MeshTools a too much 🙂
Thanks a lot!!!!sergei
Adam Trachtenberg
February 19, 2009 at 5:53 pmSounds like what you want is actually the edge cut tool. So first use ring selection, then edge cut.
Carver Koella
February 2, 2011 at 11:02 pmFor anyone finding this now, I found better luck doing what I wanted by ring selecting the edges and then using the Connect command found in the structure tab (or you can just right-click, of course).
(v 11.5, here)
