Activity Forums Maxon Cinema 4D Mesh Deformer lagging 1 frame behind with simulation
  • Mesh Deformer lagging 1 frame behind with simulation
    Posted by Eric Pereira on May 5, 2025 at 9:15 pm
    I have tried to change hierarchy, but nothing I do so far can stop the 1 frame lag for rigid body dynamics.
    I even tried a simple sphere object with mesh deformer set to a cube.
    The cube then has a rigid body tag.
    I have 1 frame lag in the viewport, and when I wiggle the mouse, the lag jumps to the present. However, with my IPR window (Arnold), the render also shows the lag behind which only corrects in viewport and render when I move the mouse.
    I moved the cube object below the sphere in the object manager, but the result is the same.
    What am I doing wrong?
    I am on C4D 2025.1.1, but I don’t see this as a bug fix in any recent patch.
    It even occurs when I cache the rigid body.
    Kouraib Abdmalek replied 1 year, 4 months ago 2 Members · 5 Replies
