Activity Forums Adobe After Effects merry-go-round
  • merry-go-round
    Posted by Duncan on July 31, 2006 at 12:14 pm
    Afternoon, I’m finding my current project rather labour intensive. Anyone think of a better way to create the following…
    15 images facing the camera, spread out in a circle shape, so when viewed at the front and animated clockwise they all rotate around a center null object, a bit like a kids merry-go-round or carousel.
    What I’m doing at the moment is placing a new layer, duplicating it and then rotate and changing its position, seems to be taking awhile.
    Cheers.
    Duncan replied 20 years, 1 month ago 2 Members · 3 Replies
  • Ken
    July 31, 2006 at 1:20 pm
    Off the top of my head, you could position your null in the center and the first layer at the 6 or 12 o’clock position (when viewed from the top). Once in position, apply an “Auto Orient towards the camera” to the layer. Next, duplicate the layer 15x and parent the second one to the null. Now, rotate the null on the y axis 24 degrees then parent the next layer. Repeat for rest and you should be set. Once in place, you can simply replace the layers with your final images.
    Good luck
    Ken
  • Duncan
    August 2, 2006 at 9:41 am
    hello, loaded up 3D Assistants Lite, i cant get a perfect circle, they always seem to form a squashed curclue shape?
    thanks
  • Duncan
    August 2, 2006 at 10:23 am
    dont worry, sorted, needed 16 layers, rotated at 24 degress each.
    All done manualy, thanks.
