Activity Forums Avid Media Composer Meridien Audio Phase Bug Fix….FINALLY!
  • Meridien Audio Phase Bug Fix….FINALLY!
    Posted by Adam Bernardi on October 2, 2009 at 9:39 pm
    I know this is pretty much pointless, but if anyone has been frustrated with this problem and still on an old Meridien MC, I finally found a fix.
    The Problem: When working with a stereo track, let’s say a stereo Dialogue stem for instance, and I make some cuts, very often the stereo image shifts. Instead of the dialogue coming solidly from the center, it sounds dispersed, usually leaning slightly to the left. And when I play it in reverse, it leans slightly to the right. If you try to cut in a mono piece of dialogue, let’s say, then the image shifts solidly to the center and them back. Obviously it’s a problem. I’ve brought the problem to everyone I know including Avid and nobody has the slightest idea what I’m talking about. I thought I was crazy.
    The Solution: Anyway, I had a little time to play with this because it was giving me a headache on a current project with lots of ADR. I discovered if I pan the left channel all the way to the right, and then back to the left again, do the same with the right channel, the problem goes away. It seems to reset everything and it comes back to normal.
    Anyone have this experience, or am I the only one in the Avid community that has noticed it? BTW, this has happened on several machines, so I know it’s not just one defective machine.
    Adam Bernardi replied 16 years, 11 months ago 3 Members · 3 Replies
  • Grinner Hester
    October 2, 2009 at 11:00 pm
    In all my meridien daze, I never heard that.
    ‘grats on the fic though.
  • Bob Zelin
    October 5, 2009 at 2:13 am
    I never heard that either. And I worked on hundreds of Meridian systems. And even if I was wrong, the delivered masters to the networks would have been rejected if the audio was out of phase.
    so it’s you – not the Meridian system.
    Bob Zelin
  • Adam Bernardi
    October 5, 2009 at 8:41 pm
    That’s an interesting response Bob Zelin. I’m not sure if you’re joking or just being rude. Nevertheless, if you find yourself in Los Angeles, look me up and I’ll show you the problem. I can’t imagine what I could be doing to cause it. Maybe you can figure it out.
