Activity › Forums › Maxon Cinema 4D › Merging wires
  • Merging wires
    Posted by Olly Bea on March 26, 2008 at 1:32 pm
    Hi all (I’m on C4d 10.5)
    I’m fairly new to C4d and I seem to be a little lost with this problem I have. I have made a net by crossing several sweep-NURBS (a circle along a cubic spline) together. However where two wires cross I want them to look like when a metaball joins 2 objects together. The closest example I can think of are the Spiderman title sequences.
    Any ideas?
    Adam Trachtenberg replied 18 years, 6 months ago 2 Members · 1 Reply
  • Adam Trachtenberg
    March 27, 2008 at 4:12 am
    You can actually drag all of your splines under a metaball object and it will turn them into a metaball shape. You’ll probably have to play with the parameters and add metaball tags to get the right look.
    AdamT
    Cinema 4DXL8 Bodypaint
    *Remember: Tues. is national Shoe Day. Wear shoes to show your support for bimetalism and the designated hitter rule!*
