Activity Forums VEGAS Pro Merging split videos
  • Merging split videos
    Posted by Bert Tobben on May 21, 2010 at 1:30 pm
    Hi there,
    I’m searching the internet for I think a simple solution, but can’t find the proper answer.
    I’ve have a lot of videos on the the timeline. Now the problem is, as I slide for example a single video in the beginning of the timeline to the right, the rest of the videos will remain on their place and the one video I move to the right will overlap the next one.
    Question: how can I make it so that all videos be as one (group?). So that if I want to insert a new video in the beginning, I move the rest behind it in one move, without moving them by hand piece by piece…
    Thanx
    Bert
    Bert Tobben replied 16 years, 3 months ago 3 Members · 3 Replies
  • Danny Hays
    May 21, 2010 at 2:49 pm
    You can turn on ripple edit, or I would select all the videos you want to “merge” and hit the “G” key to group them. Now they will all move as one event. Hope this helps, Danny Hays
  • Pedro Ramirez
    May 21, 2010 at 9:13 pm
    I had exactly the same problem.
    For what I have seen, it seems to be impossible to “glue” together files that have been already divided, so you have a few options:
    1)Turn on the Ripple Tool (it is the icon on the top, with 2 boxes, and a green arrow pointing to the left. My program is in spanish, so I dont know how the tool is called in english). That tool has different options, but one of the most-used is the one with which you insert a new event, and the WHOLE project moves to make space for it.
    2)The other option (which you can combine with the first one) is to make groups. To make a group, select all the events you want to group together (INCLUDING the sound of each event. If you dont select them, they will SEPARATE from the video when you move the group!!!) by CTRL+CLICK´ing each event.
    After that, click G to group them, so they move as if they were one, or in case you change your mind, you can degroup them by pressing U (beware, this may separate the sound from its video. In case that happens, group the video with its audio again with G.).
    In case this turns useful for you, please respond back 😀
    PD: Subscribe to my starting YT account “LuciusFilmex” in case you like Halo 3.
  • Bert Tobben
    May 22, 2010 at 8:01 am
    Pedro,
    Thanx for the explanation. The first one (ripple tool) was the one I was searching for.
    Gr.
    Bert
