Activity Forums Adobe Illustrator merging shapes into one object before applying a stroke
  • merging shapes into one object before applying a stroke
    Posted by Alexandre Brandt on November 26, 2011 at 12:05 am
    Hello All,
    I’ve been doing a logo where I letters where converted into object so I could modify their shapes.
    I’ve been tweaking around and I have some letters that overlap, all white, to make it look like a seamless logo word. I’d like to now apply a stroke to it (to have a little simple black contour).
    I tried joining the connections between layers but it tells me ; “This selected objects cannot be joined as they are invalid objects (compound paths, closed paths, text object, graphs live paint group).
    What am I doing wrong ?
    Thanks for reading.
    motion pictures + storytelling = ?
    -> FILMMAKING !
    Vincent Rosati replied 14 years, 6 months ago 2 Members · 1 Reply
  • Vincent Rosati
    November 26, 2011 at 10:20 pm
    One thing you could try is to select the objects and Pathfinder / Unify.
    Or, to just add the appearance of a stroke, duplicate all of the objects and group them. Then layer them underneath the primary objects. Then you can apply a stroke to the grouped objects, and the primary objects will appear to have the stroke.
    Just a couple of ideas.
    Vince
    *Please remember to Rate our replies or check Solution if solved. If you get a good idea from the post, consider clicking the Kudos option.
