Activity Forums Adobe After Effects Merging separate shape paths into one
  • Merging separate shape paths into one
    Posted by Jason Brown on May 20, 2016 at 7:55 pm
    Okay, I have 2 shape layers made up of individual paths forming the whole. The desired effect is to transform shape 1 into shape 2 by keyframing the shape paths.
    However shape 1 has 5 sub shapes and shape 2 has 3 sub shapes.
    All is fine when I copy a single shape path from shape 1 and keyframe into a shape path from shape 2, so I go:
    copy and paste
    path 1 to 1
    2 to 2
    3 to 3
    these all transform fine, but I have 2 leftover shapes.
    4 to ?
    5 to ?
    I’ve tried copying all the shapes paths (3,4,5) and pasting them into a single shape layer but that doesn’t give me a single shape path, they’re still individual and the shape doesn’t appear it just shows the path outline.
    Any help is much appreciated,
    Jason Brown replied 10 years, 3 months ago 3 Members · 3 Replies
  • Greg Gesch
    May 22, 2016 at 3:58 am
    Hi. The only thought I have is to duplicate (say) paths 2 and 3 in your final shape layer, then when you want the two missing paths to appear keyframe paths 4 and 5 onto the duplicates – it would mean the peel away from the existing shapes though.
  • Graham Quince
    May 23, 2016 at 8:57 am
    Are you copying the keyframed paths or just the paths themselves?
    Have you seen Chris Zwar’s tutorial on morphing. It might help a little.
    http://www.YouTube.com/ShiveringCactus – Free FX for amateur films
    https://shiveringcactus.wordpress.com/ – FX blog
  • Jason Brown
    May 23, 2016 at 2:13 pm
    Thanks for the replies.
    I kind of found a fix that worked for me. The 2 left over shape paths I had I just keyframed their position and scale and hid them behind the other shapes, so it appears as 2 shapes morphing into one.
