Activity Forums Apple Final Cut Pro Merging projects…
  • Merging projects…
    Posted by David Battistella on July 31, 2011 at 6:12 pm
    I had a thought, but before I submit this as feedback I thought I’d has it out here.
    When I got into larger projects in AVID and FCP legacy I often would have a series of sequences. Depending on how I numbered those sequences I could easily build an assembly of a longish 30-90 minute program.
    By changing the sequence title:
    001
    002
    003
    I could quickly order or reorder scenes in an assembly.
    Now in FCP X I could have all the sequences in compound clips in the whole sequence but I prefer to work in smaller bits while working toward a larger assembled piece.
    I’m thinking of implementing this at the project level with folders and multiple projects. I have found the copy pasting between sequences is slow in FCP X.
    So I am thinking that a “merge projects” might be a very handy command that could quickly allow an assembly of multiple projects to be constructed with a keystroke.
    IE
    Merge projects opens a window that allows you to arrange all of the “projects” into a master assembly project.
    I still like working in reels as I think as timelines and projects grow the software can start to chug. I can imagine this being a bit if a problem in FCP X with larger longer projects.
    Thoughts?
    ______________________________
    The shortest answer is doing.
    Lord Herbert
    https://vimeo.com/battistella
    David Battistella replied 15 years, 1 month ago 2 Members · 2 Replies
  • Jeremy Garchow
    July 31, 2011 at 8:58 pm
    A nesting of projects could also be nice. So, each project becomes a compound clip of sorts in to a master project. That way, you could add/delete/rearrange from the index.
  • David Battistella
    August 2, 2011 at 4:57 am
    That would indeed be nice. That’s exactly the kind of functionality I am suggesting/talking about.
    David
    Lord Herbert
