Activity Forums Square Box CatDV Merging Metadata into one asset record
  • Merging Metadata into one asset record
    Posted by Gerald Goldman on July 12, 2012 at 5:03 pm
    Over time, we have copied asset records for the same file into multiple catalogs. Now those records are slightly different. Is there a way to merge the metadata together, so all of the records have all of the same metadata?
    This is not a case where the data would be contradictory, there are just different fields filled out in different catalogs.
    I hope that makes sense.
    Any help is appreciated.
    Gerald Goldman
    Director of Post Production
    Grace Creek Media
    CatDV Enterprise Server v.8.1.11
    Gerald Goldman replied 14 years, 1 month ago 2 Members · 2 Replies
  • Rolf Howarth
    July 12, 2012 at 8:28 pm
    Yes, you can use the Paste Metadata command for that, telling it to merge or append the data rather than overwriting it. (You need to enable advanced menus via the General tab of Preferences to see that command.)
  • Gerald Goldman
    July 12, 2012 at 8:37 pm
    Got it! Thanks so much
