Activity Forums DaVinci Resolve Merging EDL’s through Resolve Question
  • Merging EDL’s through Resolve Question
    Posted by Kevin Camilleri on November 3, 2010 at 9:05 pm
    So I received an EDL for a particular job that has been split in two. I have been able to bring in both EDL’s and pre-conform them separately, but now I want to merge them into one timeline. I know I can merge the EDL’s using FC, but I would like to know if there is a way that I can do this using Resolve.
    Any help would be appreciated,
    kevin
    Kevin Camilleri replied 15 years, 9 months ago 3 Members · 4 Replies
  • Kevin Camilleri
    November 3, 2010 at 9:45 pm
    Figured it out using the scene menu… just loaded in both EDL’s from there, preserved existing info and it worked…
  • Ola Haldor voll
    November 3, 2010 at 10:28 pm
    Nice find. Finding things like this proves Resolve is robust.
  • Robin Erard
    November 8, 2010 at 3:07 pm
    Hello,
    I don’t understand how you did this… Could you give the detail of the process ?
    Robin
    réalisateur, scénariste, monteur
    http://www.robinerard.ch
  • Kevin Camilleri
    November 8, 2010 at 7:21 pm
    I was able to get this to work while using a large clip of the entire show I was working on.
    I obtained the clip using the “crash record” function while it was being recorded to tape.
    Once I saved the clip I went to the “BROWSE” menu, found the clip, right click on it, select the “Scene Cut Detection” option. This should automatically re-direct you to the “SCENE” menu. Here you hit the “Load EDL” button and proceed to load the first part of your EDL. Repeat this step for the second part, but when it ask you if you would like to retain the previous scene information click “preserve” and it will merge both parts of your EDL. You can do this for the remaining parts of your EDL, when you are done I would recommend saving your new EDL.
    I have yet to try this with a multi-layered video timeline, you may have to compress that first in FCP or AVID…
    I hope this helps,
    kevin
