Activity Forums Apple Final Cut Pro Legacy Merging audio layers.
  • Merging audio layers.
    Posted by Paul Coull on February 15, 2007 at 1:53 pm
    I am editing some snippets together in final cut, but some audio levels are low. Even having the levels up at 12db has left me with having to duplicate the audio levels. The problem I have is now, is when cropping the clips only the original audio tracks crops the duplicated audio layers have to be done separately. Is there a way of either combining the audio layers into 1. Or relink the audio files to be in sync with the video?
    grafxflow
    grafx that flow!
    Paul Coull replied 19 years, 7 months ago 3 Members · 4 Replies
  • Bret Williams
    February 15, 2007 at 1:56 pm
    You can highlight all the items and nest them, creating a single clip essentially.
  • Paul Coull
    February 15, 2007 at 1:59 pm
    Hi Bret,
    Thats works great, thanks for the quick reply.
    regards
    grafxflow
    grafx that flow!
  • Jerry Hofmann
    February 15, 2007 at 2:01 pm
    You can also select the layers, and force a link (in the modify menu)…. cmd+L is the keyboard shortcut.
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
  • Paul Coull
    February 15, 2007 at 2:31 pm
    Stuck for choice!!
    regards
    grafxflow
    grafx that flow!
