Activity › Forums › Avid Media Composer › Merging 2 Avid Projects
  • Merging 2 Avid Projects
    Posted by Gaby Granda on March 15, 2017 at 1:03 am
    Hi!
    So I linked, transcoded, and synced some media in an Avid project. The plan is to combine this with another separate project on another drive (for the sake of this, Drive A), which I’m planning on doing by copying and pasting .avb files. Currently, my media is on a floater drive (Drive B), but I plan on copying over the assets I’ve been working with from the floater (drive b) to Drive A. Anways, I guess I’m scared that Avid will have trouble relinking once I’m working off another drive. I’m pretty rusty in Avid, but any tips/explanation on the best way to do this without it turning into a relinking headache would be very helpful. Thank you!
    Gaby Granda replied 9 years, 6 months ago 2 Members · 2 Replies
  • John Pale
    March 15, 2017 at 4:08 am
    Should be no problem. Its pretty common to do this. Avid looks for Media Databases on whatever drives are connected on startup. It doesn’t care if you move the media to a different drive. You probably won’t even have to relink.
    ***This applies to Avid Managed Media, not Linked (AMA) media…which can be a bit more finicky (but still possible)
  • Gaby Granda
    March 15, 2017 at 4:21 am
    Thank you so much! It actually is AMA linked footage. Are there any extra steps since that’s the case? Thanks, again!
