Activity Forums Adobe Media Encoder Merge/Passthrough Audio with Video?
  • Merge/Passthrough Audio with Video?
    Posted by Weston Jones on April 24, 2018 at 7:10 pm
    This isn’t about help with Media Encoder per se, as I’m nearly certain it’s something I can not do with Media Encoder, but hoping others here have same issue:
    Since Adobe’s drop of Dolby Support, (AH HEM!), I am unable to export an MP4 with a 5.1 surround AC3 file.
    I have my video file as a ProRes master, and can encode it to an MP4 or anything else. I have a sound file from my sound designer encoded as a working AC3. I just need to combine the two files. How can I do this? Is there other software out there that just combines/passthrough’s A/V tracks as one file, without encoding?
    I also have a the mix as a WAV file with the mono surround stems, but I’m guessing this isn’t helpful as it would need to be encoded. I tried encoding to an Mp4 from a ProRes file with the WAV file attached, using HANDBRAKE, but this did not yield a working surround file when I played it back.
    Any help greatly appreciated!
    Thank you!
    Weston Jones replied 8 years, 4 months ago 1 Member · 1 Reply
