Activity › Forums › Apple Final Cut Pro Legacy › Merged clips unlink after XML export
  • Merged clips unlink after XML export
    Posted by Jeffrey Buras on January 20, 2010 at 6:37 am
    A search in the forums hasn’t helped me with this problem.
    The audio and video were recorded separately. The audio from the camera is just a guide track (and sounds terrible). The two source files (audio + video) were merged in Final Cut Pro.
    The problem comes up when I export an XML. After I import the XML back into a project, Final Cut just seems to forget about the merged clips. In the bin the “Type” column no longer says “Merged Clip”, it just says “Clip”. The “Tracks” column changes from “1V, 4A” to “1V, 2A”
    Any thoughts? Am I missing something?
    Andy Mees replied 16 years, 8 months ago 2 Members · 3 Replies
  • Andy Mees
    January 20, 2010 at 7:33 am
    what version of XML export … I just tried to duplicate the problem here using XML v5 and it worked perfectly
  • Jeffrey Buras
    January 20, 2010 at 8:37 am
    I’m using XML version 4.
    I think I’ve found the problem. If the merged clip is used in a sequence, it stays merged in the bin. If the merged clip is not used in a sequence, Final Cut forgets about the audio.
    So now I’m make a throw-away sequence where I dump everything from the bin before export.
  • Andy Mees
    January 20, 2010 at 9:06 am
    Might be FCP version specific, as it seems to work just fine here (on FCP 7.0.1) regardless of the xml version used for export and regardless of whether the clip is is used or unused. Glad you found a workaround anyway.
    Best
    Andy
