Activity › Forums › Adobe Premiere Pro › Merged Clips Failure/This Project Contained a Sequence That Could Not be Opened…
Posted by Chase Carnahan on November 23, 2011 at 4:28 amIt seems that merging my clips together in PP 5.5 errors out my project file, and when I try to reopen the project file, PP gives me an error message: “This project contained a sequence that could not be opened. No sequence preview preset file or codec could be associated with this sequence type.”
I seriously don’t know what’s going on. I’ve tried a variety of different import settings/sequence settings…but every time I end up getting the same problem. If anyone knows a workaround, or a fix for this issue, please help!
Chase
David Phinijdamm replied 9 years, 9 months ago 8 Members · 9 Replies -
Vince Becquiot
November 23, 2011 at 5:40 pmHi Chase,
I’ve seen this happen with sequences made using an i/o card preset that is no longer available.
Eg. AJA / Blackmagic card or software that are no longer there.
Vince Becquiot
Kaptis Studios
San Francisco – Bay Area -
Chase Carnahan
November 23, 2011 at 6:59 pmHey Vince,
Thanks for your reply. My sequence settings are native to my 7D’s 1080p/24fps .mov files, and my audio files are both taken from my Zoom H4n @ 48.1 hz. (I create the sequence to match the files by dragging my clip to the “new item” icon.)
If it is indeed what you are saying, and PP 5.5 is creating a preset that is write-able but not readable, what are my solutions? Am I limited to just syncing and leaving all my clips/takes on one timeline? or moving them all to separate sequences and cutting from there?
If there is no workaround, are there other codecs I can go online and download for 5.5?
Chase
Chase Carnahan
November 23, 2011 at 7:07 pmHey Vince,
Chase
Steven Shippee
February 26, 2012 at 6:35 pmI had the same error, to wit, “This project contained a sequence that could not be opened. No sequence preview preset file or codec could be associated with this sequence type.” in Adobe’s CS-5 Master Collection 64 bit edition of Premier.
It was a result of having installed the trial version 1st, which installs without the codecs.
The workaround is to install a new project after converting the trial version to a paid, registered version – then the new project will auto install the correct codecs and you are good to go after than.
Steven Shippee
Olympia, Washington -
Raffael Krieger
July 19, 2012 at 10:40 amSOLUTION on PC!
Open the project file in editor and search the entry: “.epr”
If there is something written like “I-Frame only…” replace it like that: “Microsoft AVI.epr”Thats the preview format, which can come in a working project through importing some other sequences, which contain the i-frame preview settings…
Tell me if it works for You too!
Hayley Harrison
April 2, 2013 at 5:08 amHi there,
Do you know which codecs need to be downloaded in order to resolve this problem?
-HH -
Didier Jeanjean
October 27, 2013 at 10:31 pmHi there!
I got the same problem as you guys with premiere cc. When I merge a video and a sound, the next time i try to open the project i can’t and it says “This project contains a sequence…”
Did you find out the codecs needed to open project with merged clips?
I’m in despair right now… No one on any forums talks about this problem
Thanks a lot!
Benoit Demarle
December 23, 2013 at 2:37 pmHi to all,
Exact same problem on Premiere Pro CC. A project that must be finished in a week cannot be open because of merged media (7D images + H4N sounds).
Does anybody has a solution for this ?
Thanks for your help.
