Activity Forums Adobe Premiere Pro Merged clips causing problems with bottom (Audio) half of timeline
  • Merged clips causing problems with bottom (Audio) half of timeline
    Posted by Matthew Macar on June 1, 2012 at 8:15 am
    So, weird weird weird issue I’m coming across…
    I just went through and logged, synced, and merged all the footage and audio from a shoot Tuesday. 5D h264 and wav audio. I assembled one of the scenes no problem, and went to start roughly mixing audio….now here’s the fun part…
    Everything was fine until I went to expand one Audio track 2, 3, or 4 so that I could see the waveform and keyframes and I noticed that the bottom half of the timeline (that audio half) didn’t react at all (didn’t expand). I zoomed in and it corrected itself, showing the now expanded audio tracks, but when I clicked on one of the tracks, again, no reaction. I tried scrolling horizontally, and the top half of the timeline scrolled normally as you would expect, but the bottom half became all distorted and useless and a couple of the tracks turned completely black. Basically, it’s making it impossible for me to edit the audio and turning my timeline into a cluster f…I’ve tried setting up a test edit with the original h264 files with just camera audio and that doesn’t pose a problem so it seems to be an issue with the merged clips. I’ve heard of issues with wav format in PP from before…any chance that might be part of it?
    Here are the troubleshooting steps I’ve taken:
    Relaunch PP
    Restart computer
    Save as different project
    Duplicate sequence with different name
    Create new sequence and copy from original into new
    Import sequence from original project into new project
    Trash preferences
    Reinstall PP
    Reinstall Master Collection
    Next thing I’m gonna try is converting all the audio to AIFF and then relinking each audio file in PP to the new AIFF files. Thoughts?
    System specs
    Late 2009 Macbook Pro
    2.93 intel core 2 duo
    8gigs ram
    Garnet Campbell replied 13 years, 12 months ago 3 Members · 2 Replies
  • Cyrus Dowlatshahi
    September 3, 2012 at 3:51 am
    I have this same problem, and it occurs very randomly. Troubling.
    It tends NOT to happen with my more simple projects. I have a big one with 1000s of clips and tons of complex sequences in it… PP has crashed a billion times with this project, so maybe the project file got corrupted?
    In any event, I experience the exact same symptoms you do. Others do too.
    I’m running a 2008 Mac Pro with Lion.
  • Garnet Campbell
    September 25, 2012 at 2:43 am
    My Problem with a merged clips with 3 wav audio tracks in them is that 2 of the merged wavs… are no longer connected to the original media.. I cant figure out how to reconnect them.
