Activity Forums Adobe After Effects Merge/blend two videos/compositions
  • Merge/blend two videos/compositions
    Posted by Gigi Marzo on November 21, 2014 at 8:00 am
    I think I’m drowning in an inch of water: do you remember the union of two images with a gradient? (The web is full of tutorials, example here )
    I’m trying to do this in after effects, or rather, having two video / two compositions I would like to merge them into one, the attached picture will be much more clarifying what I mean.
    Not having the tools of photoshop how can I get it?
    Thanks so much!
    The attached picture I have worked in two seconds (with photoshop! I can not do it in AE), is not very precise and quite unpleasant, however I would like to get a clean job, with a real shade, avoiding the horrible line is formed in the middle.
    PS For made attached picture I used two different frames found on youtube.
    -Sorry for my little english-
    Gigi Marzo replied 11 years, 9 months ago 3 Members · 4 Replies
  • Graham Macfarlane
    November 21, 2014 at 9:35 am
    Hi Gigi,
    *Position your two video layers side by side in After effects. You need to make sure that there is plenty of overlap to accommodate the size of gradient you want.
    *In the timeline/layer view select the layer on top.
    *Click the Rectangle tool in the tool panel at the top of the UI (it should be just to the left of the Pen tool)
    *Then click and drag a big box around your video in the composition view to create a mask that completely covers it with plenty of extra space on all sides except the side where you want the gradient. On this side, position the mask edge at the center of where the gradient should be.
    *You will now see in the layer view, that the top layer has expanded and now shows “Mask 1”. Expand mask 1 then increase “Mask feather” until you get the gradient width needed.
    *You might see some unwanted transparency on some of the other sides with a really big feather, so just increase the mask size in those areas to compensate.
    Graham Macfarlane – CGI specialist
    Elyarch Ltd – London UK
    3D Studio Max | Vray | Pflow | PhoenixFD | After effects | Mocha
  • Gigi Marzo
    November 24, 2014 at 12:13 pm
    Hi! Thank u for ur answer!
    But I’m asking too much if I prayed you to post an example project file?
  • Derek Boettcher
    November 24, 2014 at 9:50 pm
    I’ve got you covered Gigi.
    explanation in the file:
    8220_maskingprojectfiles.zip
    Best,
    Derek Boettcher
    Creative Management
    BTH Media Group
    https://bthmedia.com
  • Gigi Marzo
    November 29, 2014 at 9:34 am
    thank u very much!
