Activity Forums Adobe Photoshop merge two text overlay layers without losing effect?
  • merge two text overlay layers without losing effect?
    Posted by Nick Dantonio on September 11, 2009 at 9:08 pm
    I’m using PS CS4 and I have two text layers on top of each other (they same the same thing) and the layer style for both is set for “overlay”. I want to merge (and rasterize) the two layers but keep the look of the doubled up overlay effect.
    Can this be done??
    Thanks…
    Fred Gates replied 17 years ago 4 Members · 3 Replies
  • Matt Sepeta
    September 14, 2009 at 4:01 pm
    I use a work-around method to accomplish this. I know that merging layers makes effects go all wonky so I figured out this method…
    I make a new empty layer, then make all other layers, except for the empty layer and the layer you wish to be rasterized invisible. Then I do “merge all visible”. Then repeat. You lose the ability to change the effects, but it might work for what you are trying to do.
    Good Day
  • Richard Harrington
    September 14, 2009 at 4:50 pm
    Make a new layer first and hold down Option or Alt when merging to merge a copy to the selected layer
    Richard M. Harrington, PMP
    Author: Video Made on a Mac, Photoshop for Video, Understanding Adobe Photoshop, Final Cut Studio On the Spot and ATS:iWork
  • Fred Gates
    September 15, 2009 at 9:07 am
    quick and dirty = put new layer under the text layer and command E
