Activity Forums Adobe Photoshop Merge to HDR
  • Merge to HDR
    Posted by U. Bürgler on April 28, 2005 at 10:02 pm
    Hello everybody
    I have a strange Problem. When I choose the “Merge to HDR” automation everythings works fine until the final image would be created. Here is step by step what I do and what happens:
    -I choose FILE->AUTOMATE->MERGE TO HDR…
    -I choose the 4 sample-pictures wich come with CS2 with the BROWSE button
    -OK
    -The preview looks fine and I leave everything as it is and just click OK
    -Then I get the folowing errormessage: “COULD NOT COMPLETE THE MERGE TO HDR COMMAND BECAUSE A COMMAND WAS NOT AVIABLE”
    I also tried to use other source images with the same result. I’m able to open existing 32bit images and to alter them without any problem.
    If a 32bit picture is allready open when I run the merge command then theres no errormessage, but all it does then is to copy the existing picture and to darken the 32bit picture wich was allready open.
    I installd the demo of the CS2 on another machine and there everything works fine…. But the OS and hardware is diffrent on that machine (W2K)….
    On the machine wich causes the problems I run Windows XP SP2 with 1GB Memory and its the downloaded Upgrade from the Adobe onlineshop for my existing CS Version.
    Sorry for my bad english, but I hope You understand my problem.
    Thank You very much.
    U. Bürgler replied 21 years, 5 months ago 1 Member · 0 Replies
  • 0 Replies
