Activity Forums Maxon Cinema 4D merge objects question
  • merge objects question
    Posted by Richard Lutz on August 5, 2012 at 9:29 pm
    Quick Question. When I bring an object into C4D from illustrator and hit render I see an outline around my object. Is this normal and how do I fix it?
    Brian Jones replied 14 years, 1 month ago 2 Members · 3 Replies
  • Brian Jones
    August 6, 2012 at 5:08 am
    more information please, can you post a screen grab?
  • Richard Lutz
    August 6, 2012 at 6:25 am
    I figured it out, but I’m having a new problem. If you look at letters that have holes in them appear to be solid. Is there something that I should do to fix this when I bring things into C4D or is it something I did in the software?
  • Brian Jones
    August 6, 2012 at 5:08 pm
    when you import splines from Illustrator if you don’t connect the splines when importing them (in the import dialog that comes up when you Merge) you have to connect the splines of letters that have more than one spline making them up, the ones with holes, yourself with the Connect command (or Connect and Delete)
