Activity Forums Adobe After Effects Merge (morph) two masks into one
  • Merge (morph) two masks into one
    Posted by Dewet Van rooyen on July 13, 2009 at 3:42 pm
    Hi All,
    Is it possible to merge two mask paths from one layer into a single path? If not, does anyone know of a third party plugin that does this?
    Dewet
    Hugo Castro replied 17 years, 1 month ago 4 Members · 3 Replies
  • Michael Szalapski
    July 13, 2009 at 4:33 pm
    What are you trying to accomplish?
    – The Great Szalam
    (The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)
  • Mike Park
    July 13, 2009 at 5:34 pm
    I dont know if you can merge paths directly in After Effects. If you really need to do this, I would cut and paste both paths onto the same solid layer and use the add property under the masks. If you need the mask to be one, continuous path, say to animate along, simply precomp the solid layer with both masks on it and then autotrace the precomp to give you one new mask.
    Best
  • Hugo Castro
    August 19, 2009 at 10:55 am
    Hello
    I’m having the same problem with masks merging.
    What I’m trying to do is a text layer auto-traced or outlined and then merged all the masks made from the characters merged to only one mask to be used in radio waves plug-in.
    I tried your method of copy them and paste it to a new layer and pre-composed, and then auto-trace, but I end up with the same amount of masks.
    I even tried to make a layer in photoshop and import it so see if makes a difference, but no success until now.
    Do you have any clues?
    thanks in advance
    Hugo
