Activity Forums Adobe After Effects Merge layer(clips) beside eachother without visable edges?
  • Merge layer(clips) beside eachother without visable edges?
    Posted by Niclas Pettersson on September 16, 2024 at 6:38 pm
    Hello everyone!
    Im trying to have several clips beside eachother, with the feeling of them blending in together. Im trying to get rid of the edges, ive tried masking them and increasing the feather, tried some blending modes and i’ve changed the opacity but i still see a clear line from each/some clips.
    Any ideas? Appreciate all help
    /Niclas
    John Cuevas replied 2 years ago 2 Members · 1 Reply
  • John Cuevas
    September 17, 2024 at 2:00 pm
    I messed around with some solids and it’s a little inconsistent(probably due to background and luminance) , but basically for whatever size feather you use on your mask, you need to subtract a little more than half that from you mask expansion. If you have a feather of 200, you need need a Mask Expansion a little higher than -100. Also, you can add a levels effect to each picture, change the channel to alpha and increase the contrast.
    Look at my example project.
