Activity Forums Apple Final Cut Pro Legacy merge clips?
  • Posted by Chad Mayeux on March 17, 2009 at 3:24 pm
    Recently I have been editing baseball games and they were shot with 4 different camera angles. Now we use Focus FS4 Pro HD firestore drives to eliminate capturing 20 hours worth of footage (4 tapes per angle). However, The drives seem to break up recordings into 1.85 gb clips (in raw DV format). I would like them to be one giant clip that I can import into FCP so when I go to sync them and create a multiclip, I will only have to sync 4 clips.
    If the firestore drive will only record into 1.85 gb segments, is there a way to combine or merge the multiple clips as a new single long clip that I can use for my multclip?
    If I can not do that and have to sync several times then the hard drives really aren’t saving me much time. I just find it hard to believe there isn’t a way to do this. The crazy thing is that there is a time lapse record mode (the drives are a 100gb and can record 10+ hours) that from the manual gave me the impression it would record as 1 long file but to my dismay it stored them as 1.85 gb clips in that mode as well. Any help would be awesome!
    Chad Mayeux
    Metter, GA
    Pineland Technology Solutions
    Videographer/ Digital Artist
    Michael Sacci replied 17 years, 6 months ago 2 Members · 1 Reply
  • Michael Sacci
    March 17, 2009 at 4:56 pm
    First have you even tried to play back any of these clips, I have a FS-100 and FCP (or QT Player) will not playback material recorded in Raw DV, but that maybe because the camera is outputting DVCPro50 or HD.
    But if the clips play fine there is a semi=painless way of merging the clips. If you have not started and stopped throughout the game…
    Do this for a single camera at a time. Bring all the clips into the BIn of FCP (sort by name). Select all the clip and drag to the timeline (make sure your seq. settings match your clip). If you don’t care about preserving the TC on the clips Export this seq “With QuickTime” make the movie self-contained. Work with these new clips.
    If you need to preserve the clips TC or if there are gaps in the recording (Stopping and starting throughout a single game). Drag the first clips to the timeline and adjust the seq’s TC to start on the same TC as the first clip. Then bring down all the other clips, if there is a gap just move the next starting clip to matching TC in the seq, this will leave a gap where the camera was stopped but all the clips should line up when they are all done.
    There is no way around these small clips on a Firestore, drives are formatted as FAT32 which have a 2 GB limit. Your problem only comes into play when you are trying to do a mutlicam edit like yourself.
