Activity Forums Maxon Cinema 4D Merge another project.
  • Merge another project.
    Posted by Lars Wikstrom on February 28, 2007 at 6:20 am
    I did an animation in one project that looked really good. I shot a new video clip and I imported a #d track that I did into a new project. I go to the Merge under the file menu to merge together the animation and objects from another project which works fine. I am havign problems repostioning the imported objects to a new location. I am trying to select all the key frames and the object and drag them. The problem is it is not dragging the key frames in the animation just the objects. What am I doing wrong?
    -Lars
    Lars Wikstrom replied 19 years, 6 months ago 3 Members · 4 Replies
  • Mylenium
    February 28, 2007 at 7:26 am
    That won’t work. A keyframe is a unique property/ state of animation at a given time and unfortunately C4D has no such thing as “move animation path”. You can however affect multiple keyframes by adding values numerically in the F-Curve editor or coordinate manager. All input fields in C4D support basic math, so if yoou enter +100 for instance, it will be added to the original value rather than setting it as an new absolute value.
    Mylenium
    [Pour Myl
  • Lennart Wåhlin
    February 28, 2007 at 10:37 am
    Putting your merged animated object under a Null and then move the Null should work.
    Cheers
    Lennart
  • Mylenium
    February 28, 2007 at 12:25 pm
    [tcastudios]
    Putting your merged animated object under a Null and then move the Null should work.”
    You are so right. Why do those simple and obvious solutions always escape me? I seriously need a holiday *lol*. Thanks Lennart.
    Mylenium
    [Pour Myl
  • Lars Wikstrom
    February 28, 2007 at 11:47 pm
    Thanks!, After I posted here late last night I thought of that and it did work! I needed to shoot a new background that had more light but it was a pain getting this much animated and I didn’t wnat to loose it. Here is the 3 second clip.
    https://www.sbtraveler.tv/flicks/bye.mov
    Thanks again!
    -Lars
