Activity Forums Apple Final Cut Pro Legacy merge all audio into 1 track
  • merge all audio into 1 track
    Posted by Nigel Walker on April 2, 2009 at 10:59 pm
    We have a project which needs to be exported for an international broadcaster. They need full mix including voiceover on channel 1 and full mix without voiceover on channel 2.
    We can do this with lots of mucking around but there must be an easy way to mix all tracks into 1 mono track. We will the delete the voiceover and do the same mix for channel 2.
    Any suggestions
    Nigel Walker
    Wild Films
    Australia
    Victor Perez replied 17 years, 5 months ago 3 Members · 3 Replies
  • Walter Biscardi
    April 2, 2009 at 11:19 pm
    First duplicate your timeline.
    Export > Quicktime Conversion > Audio to AIFF
    Import that back in and place that on any two audio channels available. Pan that AIFF to Channel 1. There’s your mix with voiceover.
    Mute your original voice over tracks.
    Do the Export to AIFF again.
    Import that back in, place that on any two audio channels available. Pan that AIFF to Channel 2.
    There’s your mix without voiceover.
    There you go.
    Walter Biscardi, Jr.
    Biscardi Creative Media
    HD and SD Production for Broadcast and Independent Productions.
    Read my Blog!
    STOP STARING AND START GRADING WITH APPLE COLOR Apple Color Training DVD available now!
  • Nigel Walker
    April 3, 2009 at 3:58 am
    Thanks very much for the info Walter. It is a shorter version of what I was doing, so thats great but I was kinda hoping there would be an easy fix inside FCP similar to merge or flatten in Photoshop.
    Cheers Nigel
    Nigel Walker
    Wild Films
    Australia
  • Victor Perez
    April 3, 2009 at 4:25 am
    We also export a Full mono Mix for Track1 and then a Nat/music mono mix for track 2. We then place that audio on the duplicated sequence and set our audio for the sequence as Dual Mono in Sequence Settings. The reason we set the audio is because sometimes we place Nat Only on track 3 and Music only on track 4. This way our workflow is always the same even if there is no ISO Nat or Music. Since tracks 1 & 2 are already routed we just route track 3 to output 3 and track 4 to output 4 when the additional audio is needed.
    Victor
