Activity Forums Adobe Illustrator — Merge 2 vector objects in just one ?
  • — Merge 2 vector objects in just one ?
    Posted by Richard Angelous on June 10, 2010 at 11:32 pm
    Hi, Does anybody knows how can I merge 2 different vector objects and fuse them in just one, or in other words how could I fuse the edge vector points of one object with the edge vector points of the second one and make them the same total vector ??
    Thanks for your help !!
    Satish Kr. replied 16 years, 3 months ago 3 Members · 3 Replies
  • Vincent Rosati
    June 11, 2010 at 12:02 am
    To merge two connected objects you could select both and use Window/Pathfinder: Add…
    If they are not connected and they are not in groups you could select both and Object/Compound Path/Make.
    Vince
    *Please remember to Rate our replies or check Solution if solved. If you get a good idea from the post, consider clicking the Kudos option.
  • Richard Angelous
    June 11, 2010 at 12:15 am
    Thanks a lot Vince, your answer was real quick y perfect solution, you saved me hours of work, thanks for your valuable help !!
  • Satish Kr.
    June 11, 2010 at 5:05 pm
    Its very simple, just select the two object which you want to merge as one. From window menu select Pathfinder and in pathfinder click the “add to sahpe are icon”
    https://www.Graphixcare.com
