Activity Forums Maxon Cinema 4D Mercedes Logo Help
  • Mercedes Logo Help
    Posted by Victor Nash on April 22, 2009 at 4:23 pm
    I had some help earlier (Adam) guiding me through my rough Modeling skills 🙂 I have successfully modeled the beveled star for the Mercedes Logo.. Now I was wondering if there is an easy way to create the outer ring with the same beveled center. My outer ring now is just an extrude Circle. Any guidance will be helpful … thanks
    Trevor Phillippi replied 17 years, 5 months ago 2 Members · 2 Replies
  • Victor Nash
    April 22, 2009 at 7:34 pm
    Nevermind I figured it out.. I created a disk with 2 segments and lifted the center path..
  • Trevor Phillippi
    April 22, 2009 at 7:56 pm
    You also could create something similar by the following:
    -create circle for outer edge
    -copy and scale in slightly
    -use the connect function to make one spline
    -duplicate the connected spline, scale outer edge down, and inner edge up
    -move up on y axis
    -group under loftNurbs
    It’s good to have multiple approaches to the same model in case you run into problems.
    Trevor
