Activity Forums Adobe Premiere Pro Mercalli & Transitions
  • Mercalli & Transitions
    Posted by Trip Nixon on April 21, 2011 at 3:19 pm
    Hey all. I couldnt find an applicable forum for this question, so I am trying here in the premiere forum because that is what I use.
    When using Mercalli Stabilizer on clips…after adding a transition, since the video was not analyzed on its handles…you tend to see the shaky video during the transition. But if you try to stabilize a longer clip with the handles, and then shorten it for the transitions…it will give an error and ask for another analysis.
    This is not the same question as an ERROR when stabilizing a clip with transitions already, I am quite aware of this…always stabilize, THEN add transitions…
    Any ideas?
    Alex Udell replied 15 years, 5 months ago 2 Members · 4 Replies
  • Alex Udell
    April 21, 2011 at 6:25 pm
    Hiya…
    This assumes you are cutting back to back edits on the same video track.
    1) Lift the clip up to the next available video track
    2) Trim the clip out to include handles
    3) Right CLick the clip and Select NEST from the context menu (assumes CS4 or Greater)
    4) Double Click the Nested clip to open it’s sequence
    5) Apply your stabilizing effect to the clip in this Nest sequence timeline and analyze/ process as usual
    6) Close this sequence tab (this should leave you in the parent sequence again)
    7) Trim the Nest clip object back to the intended length
    8) Move the nest clip back down to its original track
    9) Add transitions and render as needed.
    that should do it.
    Alex
  • Trip Nixon
    April 22, 2011 at 12:27 am
    Thanks! Will try that today!
  • Trip Nixon
    April 22, 2011 at 3:36 am
    Worked like a charm. Thanks a million!
  • Alex Udell
    April 22, 2011 at 4:53 am
    glad to help.
    Alex
