Activity Forums Apple Final Cut Pro Legacy Mercalli 2.0 mystery purple X
  • Mercalli 2.0 mystery purple X
    Posted by David May on March 21, 2011 at 2:23 pm
    Hi all
    Have recently purchased Mercalli 2.0 plugin for Final Cut Pro and it works like a dream.
    However, all the footage that I correct using the plugin ends up with an outline of the wireframe ‘X’ watermarked into it.
    Not only does this purple X appear on the footage in the preview window, it appears on the exported version.
    If anyone has encountered anything like this with a plugin before, some help would be appreciated. Have turned google upsidedown with no results.
    Dave
    Darin Derstine replied 15 years, 5 months ago 3 Members · 3 Replies
  • Bouke Vahl
    March 21, 2011 at 2:32 pm
    Seems you don’t have the product registered and it is still running in demo mode.
    Do contact the seller / see his site to see how you unlock it.
    Bouke
    https://www.videotoolshed.com/
    smart tools for video pros
  • David May
    March 22, 2011 at 3:48 am
    An email confirms you were right on the money.
    Great bit of software, cant wait to use it properly!
    Thanks for the help
  • Darin Derstine
    April 3, 2011 at 1:22 am
    I have the demo version of the Mercalli v2 FCP plugin also installed, and always experience a bug that the Analysis window crashes after about 10 seconds. I’ve googled and confirmed that others have experienced the issue. It’s great to hear you actually got it to work.
    I really need to use this for a project. Could you give your quick specs and what type of video files you are applying it to.
    Huge thanks!
