Activity Forums Adobe Encore DVD Menu with Video as bkgrd & Image as Button Highlights
  • Menu with Video as bkgrd & Image as Button Highlights
    Posted by Bluriie on July 30, 2006 at 4:54 pm
    Hi Gurus,
    I’m new with Encore 1.5 and reading your posts have been a great help so far.
    I’m not sure if its possible with Encore 1.5 but I would like to create a menu with a Video clip as the background… AND image as button highlights.
    I’ve seen Mr David Garrett’s tutorial on “Using a full colour picture for subpictures”, which as helped me tremendously with achieving the image as button highlights.
    However, I would like to achive the same effect BUT with a video clip as the background instead of a still picture.
    Would I have to use After Effects or Premier?
    Any advice is greatly appreciated. Thank you.
    Sincerely,
    April 🙂
    Joe Bowden replied 20 years, 1 month ago 3 Members · 3 Replies
  • Mylenium
    July 31, 2006 at 5:55 am
    Yes, you have to “bake” all image pixels into the background and for a motion menu this means using AE or Premiere. Unfortunately you cannot simply sandwich multiple image layers as you would in Photoshop.
    Mylenium
    [Pour Myl
  • Bluriie
    July 31, 2006 at 2:13 pm
    Thank you for your reply.
    Is there any link with a step-by-step process on how to get this done?
    I’m sorry, I’m really new with Encore.
    Thanks again! 🙂
  • Joe Bowden
    July 31, 2006 at 4:46 pm
    If you want to use images instead of subpicture highlighting, you will have to create a separate menu for each button, and then link each button to the next menu, which can get tedious if you have several buttons.
    Note that using images for button highlights is working around the limitations of the DVD-Video specification. I would not recommend doing this (due to the amount of work it takes and some overall compatibility issues) unless it is absolutely crucial.
