Activity Forums Adobe Encore DVD Menu Transition Links In Encore 2.0
  • Menu Transition Links In Encore 2.0
    Posted by Julian Roberts on February 21, 2006 at 9:10 pm
    I am looking for advice in relation to using the new transition links (for menu buttons – not slideshows) in Encore 2.0
    I want to build a dissolve transition between the main menu and the first scene selection menu.
    My approach has been to compile an AVI file PPro comprising the PSD file for the main menu dissolving into the PSD file for the scene selection menu.
    Having applied the resulting AVI as the transiiton link in Encore, all is fine until the movie file ends and it cuts sharply (or ‘jerks’) into the scene selection menu itself.
    Can anyone advise how I can build a smooooth transtion effect to achieve the same end? Am I using the right approach here?
    Many thanks for your advice
    Julian
    John Cuevas replied 20 years, 7 months ago 3 Members · 5 Replies
  • Joe Bowden
    February 21, 2006 at 10:25 pm
    It will be smooth from menu to transition, then the laser will have to go to the timeline. On most DVD players, the last frame of the transition will hold until the timeline begins playing.
  • Julian Roberts
    February 22, 2006 at 10:23 pm
    Thanks Joe – but I’m transitioning from one menu to another menu, not a timeline.
    Julian
  • Joe Bowden
    February 23, 2006 at 1:00 am
    Make sure your transition video has the image of both menus (at the beginning and end of the transition). This will look very smooth.
  • Julian Roberts
    February 23, 2006 at 1:20 pm
    Thanks for replying again Joe. My transition is effectively an AVI file mage up of two PSD files – 2 secs of the main menu crossdisilving into 2 secs of the first scene selection menu.
    The first part of the transition (from the Encore main menu to the start of the AVI file) is very smooth. But, the return from the AVI to the Encore scene selection menu jolts. This is only what I see in preview of course – and may be better once burnt to disc.
    I guess I was hoping that my approach in making up the AVI was incorrect. Otheraise I’m a bit lost on how to fix this….
    Regards
    Julian
  • John Cuevas
    February 23, 2006 at 2:12 pm
    It may be some extra work, but could you make your transition movie into a menu, then just set the loop point at the 2:00 mark? Then you would be moving from menu to menu. Which IMO goes a bit faster and less of a jerkiness.
