Activity › Forums › Apple Final Cut Pro Legacy › Menu settings on HVR 1500
  • Menu settings on HVR 1500
    Posted by Scott Davis on November 10, 2008 at 3:14 pm
    We just got a rental deck in and I am having weird, intermitten TC problems. I believe they are due to settings in the deck. I am capturing HDV NDF tapes. In the deck settings under “TC” do I want “INT Preset”, “INT Regen”, or “EXT Regen”?
    Also, under “Run Mode” what should I set it at?
    Thanks in advance.
    Scott Davis
    View Scott Davis's profile on LinkedIn
    Lee Berger replied 17 years, 10 months ago 2 Members · 3 Replies
  • Lee Berger
    November 10, 2008 at 7:01 pm
    Those settings are only for recording. If you are using the deck for capture none has any effect. I’ve found HDV to be unreliable for Batch Capture. One tape will be fine and another will fail to find the TC. Sometimes I have to use the Capture Now function just to get the stuff into my system. Regardless of how I capture, Batch or Capture Now I back up the media to another drive assuming that a recapture may not work.
    Lee Berger
    http://www.leebergermedia.com
  • Scott Davis
    November 10, 2008 at 7:34 pm
    “Uneliable” at best. Wow. Now I am really nervous as we are offlining (donwnconversion to DV with Kona) and then doing an online at another facillity. Is this going to be a nightmare?
    Scott Davis
  • Lee Berger
    November 10, 2008 at 7:54 pm
    Perhaps you should reconsider your workflow and work in native HDV.
    Lee Berger
