Activity › Forums › Apple Final Cut Pro Legacy › Menu Screen on AJ-HD1200
Posted by Manuel Wenger on June 27, 2005 at 11:57 pmWe
Walter Biscardi replied 21 years, 3 months ago 3 Members · 6 Replies -
Walter Biscardi
June 28, 2005 at 12:02 am[Manuel Wenger] “Wondering now if we have to hire a HDSDI Monitor just to check the menue settings”
Nope, it shows up via the SD Analog Output just fine. It also shows up on the deck itself and it’s quite easy to operate from there as long as you have the book in front of you.
Walter Biscardi, Jr.
Creative Genius, Biscardi Creative Media
https://www.biscardicreative.comNow in Production, “The Rough Cut,” https://www.theroughcutmovie.com
Manuel Wenger
June 28, 2005 at 12:06 amOK, i just found the manual on the net, regarding this, the menue should be viewable on an SD montor as well and alo in the front pannel.
So I
Manuel Wenger
June 28, 2005 at 12:08 amThanks Walter, your reply came as i was reading the manual.
best regards
Manuel -
Walter Biscardi
June 28, 2005 at 12:54 am[Manuel Wenger] ”
Thanks Walter, your reply came as i was reading the manual.”Ugh! I hate reading manuals! however, in this case, keep the manual very close by. Lots and lots of menu settings in the back of the manual that you really need to look through as you set up the deck and any time you want to make changes.
Gary Adcock
June 28, 2005 at 3:38 pm[walter biscardi] ” It also shows up on the deck itself and it’s quite easy to operate from there as long as you have the book in front of you.”
comon’ Walter you have not memorized all the 020 & 600 series menu’s yet?
for the rest of you –these set the input and output settings on all current Panasonic hd decks..
gary adcock
Studio37
HD and Film Consultation
Walter Biscardi
June 28, 2005 at 3:41 pm[gary adcock] “comon’ Walter you have not memorized all the 020 & 600 series menu’s yet?”
No and I don’t plan to. My brain already hurts from this entire HD transition. I can read the manual. 🙂
