Activity Forums Adobe Encore DVD Menu Image Resolution – URGENT HELP NEEDED!
  • Menu Image Resolution – URGENT HELP NEEDED!
    Posted by Will Gaffney on September 25, 2007 at 12:09 pm
    I’m currently in the process of authoring a DVD in Encore CS3 and have designed the menu’s using Photoshop CS3. The menu files have the following specs:
    1600 x 900 pixels @ 150 pixels per inch
    Pixel Aspect Ratio is Square
    All the images I have created are crystal clear but when I build a DVD using these images and play it back on any screen be it computer monitor or TV, all backgrounds/buttons etc are blurry and just look terrible.
    Can anyone explain why this might be and what is the best solution to rectify the problem?
    Will Gaffney replied 18 years, 11 months ago 2 Members · 2 Replies
  • Mike Velte
    September 26, 2007 at 1:24 pm
    In Photoshop CS3, begin by creating a new blank file using the Film and Video preset and the the NTSC size.
    Add your elements and preview at 100% zoom.
    Stick with NTSC safe colors and Sans serif fonts.
  • Will Gaffney
    September 26, 2007 at 1:33 pm
    Sorry, forgot to mention a couple of things…
    1. I’m in Australia and therefore use the PAL format
    2. The project is in 16:9
    Should I just use the DV Pal widescreen settings in Photoshop?
    I only ask this as all the text and images still appear distorted.
